Need op amp comparator advise
I'm looking for a good comparator to work as a gate drive for a power
MOSFET. I used an LMV321 in my simulations, but I just found out the
lead time for these devices is about 2 months.
I'm looking at rail-to-rail voltage of 0 to 5V and I need something
with high gain so I can switch the MOSFET quickly. The comparator
should also be available in a DIP package. I can always try a u741, but
I'd like to know what else is out there.
Thanks in advance.
John Jardine.
Thanks in advance.
The LMV321 is an opamp and wimpy both as a comparitor or for driving a FET
gate.
Better would be a LM393 type comparitor with something like a 180ohm load
resistor. Basically, it's available everywhere, 8 pin dil, cheaper, more
precise, much faster and even has better rail to rail voltages.
john
Rich Grise
For heaven's sakes, use a real comparator! It shouldn't be hard to
google for a suitable one, but remember, typically a comparator has
an open-collector (or open-drain) output, so you need to pull up its
output. This could be a factor if you need fast switching - you have
to size the pullup resistor to give you a fast enough rise time to
your load, while not blowing out the output device.
I don't know any numbers off the top of my head, but you might try
http://www.google.com/search?q=comparator+IC
There are other ways of getting a fast rise time, of course, like
some kind of totem-pole, or a really fast opamp, or ...
Good Luck!
Rich
Jamie
Thanks in advance.
i've always liked the LM081/2/4 etc...
W
Winfield
Thanks in advance.
Best thing for the job might be an LM311 comparator. It's readily available
and costs almost nothing, but it has an open-collector output and is
active-low, though, so you'll need a pullup resistor capable of driving your
MOSFET.
Winfield
