Need help with stepper motor & safe idea
Sammy Taylor
I need a DC stepper to make the lock for a small timer safe. Think of a flat
piece of steel about 2" x 1/2" . I drill a hole in one end and slip it onto
the shaft of the stepper then attach it there. Then mount this on the door
to rotate into and out of a slot on the jamb -- just a very simple kind of
latch that will toggle open or closed w/o power having to be continuously
applied.
How does one normally attach something to the shaft of a stepper -- can I
just weld it? What diameter shaft makes sense? Where can I get a stout
battery-operated stepper (i.e. can you help me filter the Google hits?)
What would work better than this dumb idea? (Note: the safe uses an INTERNAL
timer and battery. It must be able to latch or unlatch and STAY that way w/o
power being applied until somebody opens the door.)
Thanks.
Sammy
H
Homer J Simpson
flat piece of steel about 2" x 1/2" . I drill a hole in one end and slip it
onto the shaft of the stepper then attach it there. Then mount this on the
door to rotate into and out of a slot on the jamb -- just a very simple
kind of latch that will toggle open or closed w/o power having to be
continuously applied.
INTERNAL timer and battery. It must be able to latch or unlatch and STAY
that way w/o power being applied until somebody opens the door.)
What happens if the battery goes flat?
W
William P.N. Smith
My safes have a gearmotor that pulls a latch open, clossing the safe
re-engages the latch.
All of my electronic safes have a battery inside the safe _and_ a
battery outside the safe, so if they both go dead you can replace the
outside one and still operate it.
Alan 'A.J.' Franzman
applied.
Stepper motor? I'd use a dual-action solenoid (like those used in car door
locks).
Alan "A.J." Franzman
Email: a.j.franzman [ A T ] verizon [ D O T ] net
