Need help with relay circuit
Hello...
I need to set up a relay circuit of sorts...game show style.
If I have two push button switches, I need to set up the circuit so that the one that is activated first, lights a bulb assigned to that switch, and cancels the second from completing the circuit to light the bulb on that circuit. Does that make sense? I can kind of see it in my head but it's been a long time since I did anything like this and could use a little help brainstorming.
Thanks.
davenn
Hello...
Thanks.
there's a zillion ccts online ......
https://www.bing.com/search?q=game+...-51&sk=&cvid=55BB0D7215CC4038A0791C1F0C4B1DA7
You can make a bistable with a pair of 4001 gates or 4011 gates. You will then need a couple of transistors to supply the relay current or to switch the load directly.
