Hi guys,
I have a question please help. I did a google search but could not find anything easy to understand.
I have a 12V voltage regulator that has 4 pins. pin 4 is on/off control. when pin 4 is high (open) then there is regulated voltage on output pin (pin 3).
Now I need this for a car project. this IC is going to be connected directly to the car battery and has to regulate the voltage 24 hours except when the car is turned on(when ignition key is in on position). so I have to somehow make pin 4 low(connect it to ground for example) when I have power coming from ignition key.
First I was going to use normal mechanical relay instead of using regulator IC but since it is mechanical, it has a bit of delay.
oh and by the way I want to reduce the delay as much as I can.
using solid state relay was my other option which I couldn't find a suitable one in my local shop... I found few but they couldn't handle 2Amps...
I am from New Zealand and would greatly appreciate any helps.
cheers
cheers
