I'm trying to repair an old garage door opener, remote. It has three active components, a transistor ? (that appears to be open) (8632 BEC Motorola 830), somebody tell me they know what this is,
A diode 1N4736A is a 6.8V 1W zener. (tests front to back ratio 5.5 meg to open) - (circuit - 9V supply, 6.8kΩ 1.3mA current limiter, holds voltage at 6.7V) so it's fine,
and an (SC370524P Motorola DQD8825 - 18 pin DIP) - (it is directly off of a 20 pin gang DIP switch to set the code) ?.
I would estimate a manufact. date in the early 70's. I'll draw out the circuit and get voltage measurements at various nodes and test values of passive components. I hate it when information on a component is missing in action. I understand it on stuff from the 10's and 20's but this isn't that old, and proprietary data withheld should be against the law. Well in my opinion. A little insight, it worked fine until water dripped on it from a roof leak in my garage. Pfhitt. Yeah the leak is fixed, didn't know I had it til Pfhitt.
