This is about my SP-01-N4/CEG007100 project. Basically a motion detector controlling a strobe light.
I intend to power the control circuit with a 9 volt clock battery and the strobe circuit with a 9 volt lantern battery.
As someone has kindly pointed out, the CEG can produce about 3 volts. I would think that would be able to turn on a power transistor, if applied to the Base lead.
Suppose I use a generic power transistor as the switch and a current limiter to feed the LED strobe?
I'm trying to avoid resistors as much as possible because I have a lot more VRs and PTs than resistors.
I guess I have two questions.
1. Could it work?
2. Would it be efficient?
1. Could it work?
