K
Keith
Hi folks. Kindof newbie with electronics at the component level, def
not an engineer.
I have a 5-volt pulse, from an Atmel 2313, running about 5KHz at
around a 60 percent duty cycle, that I am using to drive a heavy duty
auto ignition coil, currently (no pun intended) at about 28 Volts DC.
I have good sucess obtaining the quality of Plasma discharge cloud
that I need, albeit short sucess, using a Darlington NTE262 PNP
transistor. Short sucess, because it can't handle the amperage for
any real length of time. So I want to move to MOSFETs, but directly
driving the MSOFET from the 5-volt signal doesn't seem to drive it
into full conduction. Do I need to add a intermediate stage to drive
the MOSFET at a higher voltage than 5 volts? A simple transistor or
opto isolator perhaps? Thanks for any input.
Keith
not an engineer.
Keith
