Hello and thanks in advance for any help.
I'm trying to hook up an alarm input on a PA system. It's just an open contact input that sounds an alarm when closed. My problem is I'm trying to use a float switch that is 1400 feet away. I believe the long distance is causing it to malfunction. I've tried to run wires directly from the alarm input contact to the float, but it just alarms right away. I've tried to use a dry contact relay, but same result. I then tried to use a 110v relay which will work for up to a week at times, but it occasionally malfunctions or energizes the coil when it shouldn't. Looking for suggestions on how I can get this to work. I attached some amateur drawings so show what I've tried so far.
Also, here's a link to the dry contact relay I tried... http://www.functionaldevices.com/pdf/datasheets/RIB21CDC.pdf
and the input module on the PA system... http://www.toaelectronics.com/media/specs/s-04s_t_sa1e.pdf
