I am getting a few DRC errors in eagle CAD
I just want to know if they can be ignored or fixed.
1) Dimension: I have used the 3.5 mm jack kibrary provided by sparkfun
However on Design Rule Check it is showing the dimension error.
Should I make any amends or it is fine to ignore this error?
2) Drill Size: I didn't quite understand what exactly is wrong here.
3) Overlap: Here wire of the same signal is overlapping with the pad and the via.
Is it fine to ignore this error or I need to make amends?
4) Stop mask: I am getting this error in two of the libraries I myself have made.
Is it fine to ignore the error? Or is it necessary to change the layer from tplace to tdocu?
5) Width: The ICs I am using have the pad width of around 8~9mil.
So accordingly I have kept the wire width to 9mil as well.
Also the operating current is in micro amperes.
So is it still necessary to increase the width of the wires?
![stop mask.jpg stop mask.jpg](https://makerv2.webteractive.co/forums/data/attachments/14/14280-3e5ceb1f96fe35dbe9a56c0c323457ad.jpg)
![dimension.jpg dimension.jpg](https://makerv2.webteractive.co/forums/data/attachments/14/14277-a82b2bec1ea07ff8eb459c504c57516e.jpg)
![drill size.jpg drill size.jpg](https://makerv2.webteractive.co/forums/data/attachments/14/14278-f7b632c08578b60784fecffaf04698e9.jpg)
![overlap.jpg overlap.jpg](https://makerv2.webteractive.co/forums/data/attachments/14/14279-7bf04b49b7f29bfd0e2edf143bc516e1.jpg)
