Looks like a HV-180 Honeywell commercial floor fan with 16" cage.
Comes from my buddies industrial garage, he cut wires from before switch (bad switch). Stayed in garage collecting dust, but it's actually barely used. I want to use it for work, always need fans to dry.
Took it apart, motor is clean and spins freely, no wiring diagram to follow, used online sites to do my best...lots of research and almost ready to give up!
Motor is a DM-514G with 5+2+1 wires
Red, blue, yellow, white and grey comes from winding from what I can tell
2 black with continuity seems to be thermal fuse
1 earth ground to frame
Continuity between white and r,bl,y...and grey with r,bl,yellow. But not white and grey.
I bought a lutron fan switch 1.5 amp 2 black wires which I was going to wire the high and use switch.
I bought a start capacitor 3.0 uf 2 red wires
I tried following a few diagrams, these two seem to be the ones I need to follow (see attached) but I only get humming.
