Need help with Clap Activated Switch Kit Please
It looks like the relay is rated for 240V 10A (although that is just from looking at the image) so from that perspective the answer is probably yes.
However the circuit required external power, and you would have to build it inside an enclosure so you don't kill anyone.
If you're not familiar with mains wiring you should not attempt it.
The relay is rated for 240V, but the relay just switches things on and off. The circuit itself must be powered. It is not powered from the mains.
If you look at the board, it as a socket for input power labelled 12V 150mA. So you'd need to provide that too. I would consider a plug-pack, but for testing purposes I guess batteries could be used.
