OK, here's what I mean by a tidy schematic:
I won't bother describing the changes individually because I already did that in post #2.
This schematic and the scope traces are done with LTSpice, a free circuit simulation tool you can get from
http://www.linear.com.
LTSpice doesn't have multimeters, so I've used a "load" symbol for them. It also doesn't have an oscilloscope - monitoring waveforms is done by clicking on the schematic, with the waveform appearing in a separate window above the schematic, as you can see.
As for the question, it seems the answer is pretty simple. The circuit itself isn't an oscillator; it's just an inverting amplifier. It just amplifies (and inverts) whatever signal you put into it; this signal comes from signal generator V3.
At present the signal from V3 is a square wave that's 0V for 0.5 seconds, then 1V for 1 second, repeating. I got those figures from the diagram in post #3. The diagram in post #1 has different timing figures.
As you can see from the green trace on the oscillograph, the total period of this signal is 1.5 seconds. Therefore its frequency is 0.667 Hz. The question asks you to "achieve an approximate frequency of 1 cycle per second (1Hz)". Since the frequency is completely controlled by the settings of signal generator V3, you need to change those settings to give a frequency of 1 Hz, which corresponds to a total period of 1 second, instead of the current settings which give a total period of 1.5 seconds.
