I built a replica fire call pedestal for no particular reason. We use a magicjack VOIP for the home phone. I had hopes of using a bright bulb through a telephone signaler. This did not work because that telephone signaler needed too many volts to initiate the light once there is a call than the VOIP delivers. A landline produces around 40 volts. Some people hack this to obtain free power from the phone company. I did purchase a Phone Flasher:
http://krownmfg.com/shop/phone-flasher/
that only needs around 20 volts and does work with the VOIP. Unfortunately, this phone flasher can barely be seen. Is there a way to use the phone flasher but amplify the power transmitted to power a regular light bulb? I can use power from an outlet or batteries, whatever, but there has to be some device between the phone flasher and light bulb.
Perhaps there is a better device than the Phone Flasher, but after researching for some time, I did not find one.
Thank you for the time and consideration in looking into this situation. I very much appreciate it.
