Hello all,
I have a display board at hand (attached a picture below) with Several functions listed below:
1. It has 2 x 12 volt rail input that is powered from a power brick that is rated 12 v with 6 amps max.
2. It has a small keypad and Power Switch input
3. It has I/O power output
4. It has CCFL Backlight Circuit output
5. It has LCD circuit output
6. It has DVI output
It is a custom made Display Driver that runs a Genesis GM1601-LF chip.
Something happened to this unit and unfortunately I was not there when it happened and everyone who was there is blaming the other for what happened to it so its impossible to get an accurate account of the situation but, what I understand is that a false connection was made to the power and either the 12V rails were swapped (+ and -) or another power brick was used on the unit and whatever the reason was now it is not working.
I check the I/O power output for another board that on the circuit and no power arrives at those rails. I have limited electronics knowledge (I can solder and make small circuits) but I want to fix this thing. My questions are:
1. What parts of it should I check to find faults?
2. Could this just be a diode problem or a problem with a part that I can replace?
3. Any other thing that comes to mind?
Thank you in advance.
Baris
Baris
