Hi all. I gutted an old home organ build a virtual pipe organ and want to use the original volume pedal but it's weird. It has a linkage on the left and right with a pot connected to each.
I bought a new 10k pot to use with my controller pcu and wired it up just fine. Supply voltage is 5v, wipe goes from 0-5 respectively.... except when installed in the pedal, because the linkage only allows the pot to rotate 1/2 way. So my thinking is that the mfg (Conn) used the two pots somehow in tandem so that when the 1st pot reaches goes from 0 - 2.3 and the 2nd pot's starts at half up going from 2.3 - 5 volts.
I could be way off here but I am hoping someone can help with some insight. The output from the pedal can only go to one control terminal on the cpu so it has to be combined. Here's a picture of the pedal
http://forum.highlyliquid.com/picture.php?albumid=14&pictureid=62
and a picture of the control pcu reference. It's exactly how I wired the single pot.
http://forum.highlyliquid.com/picture.php?albumid=14&pictureid=66
I may have spewed too much info so i apologize if so. Nutshell- can two pots be used to achieve 0-5 volts with each only rotating half way?. Thanks so much for any help you can give, guys.
