Thank you 73's. Yes this cable does have the foil, you mention. in the picture, you are referring to the actual cable shroud or sheathing is obscured by my fingers.
So, I'm guessing then, that I should use the bare wires, then as a ground and prepare it by first twisting the ends, then take a short length of coated wire and solder it to the bare wire and insulate it under the heat shrink tube. Now, I would have my seven pins and seven wires to proceed.
Does that sound right?
