Hi Everyone i am new in this forum and heard about the best support compare to others and i am here to get the solution for my project which is based on solar and the basic requirement of my design is the lowest possible current on battery low condition.
the components available to build my project is LM324 zener diode resistors and PNP and NPN transistors.
the requirement of project to sense battery voltage in low and high side to add UVLO and OVLO protections in circuits which can make SHDN pin low in both the conditions at a predefined level with some hysterisis and the current in both conditions from the source should not go beyond 5 miliamps.
Here if anybody can help me out to get a circuit which can give me the desired results than i will be thnkful to him.
Plssss plssss help me out to get the solution.
