This circuit was designed for me a couple of years ago to detect an
interruption in a static laser beam by a photocell.
+5>---+-------------+
[68k] [LDR] +---[1M]--+
| | | >--+---->OUT
[100K]<--[10K]---|--------|-/ |
| | LM324 [1.5k]
| [3.9k] |A
| | [HLMP4700]
GND>--+-------------+--------------+---->GND
[You might need to copy this to notepad to see it properly]
It worked really well, but I've since built a scanning laser that
creates 10 beams from one single source, switching the beam on and
off, and moving a galvanometer mirror very quickly.
So now the beam passing through the sensor is "pulsed" - the laser
software is set to 10,000 points per second - so you can imagine how
fast this occurs.
I suspect that I need to add a capacitor to the circuit, either at the
input, output, or the feedback section to smooth out the pulses to a
more acceptable TTL signal. I'm not sure which is best, or the value
of the cap I should use.
Any help is greatly appreciated.
Dave
| | | >--+---->OUT
| | LM324 [1.5k]
| [3.9k] |A
| | [HLMP4700]
fast this occurs.
Dave
