hello all i am trying to create safety device witch will stop blind from going down if something is in the way
motor i use is somfy 30rts 24v dc dry contact control i did some test connected motor with dc current tester and check current then blind going down it was 160 mA then blind going up it was 540 mA and then blind going down and hits chair and all blind weight held by chair not motor current goes up to 250 mA so i think how to get it once current goes to 250 mA from 160 mA blind to drive up instead material overlapping and damaging everything another idea is to try use FSR resistor
to measure blind and bottom bar weight and get it to switch up once blind weight resting on any optical
