L
loadhawg
I have a very specific one-off project. It's a small clear plastic
cylinder closed at one end, 5cm (2") diameter and 2cm (.75") deep. I'm
placing the electronic components/battery in it and need to 'fill up'
the rest to the top with what I believe is called a potting compound
(like an encapsulant?) and make it air/water tight.
More specifically it needs to cure or dry to still be 'soft' -
absolutely no firmer than household silicon caulk. But it needs to
pour in with thin water-like viscosity so that it fills up any air
pockets etc. Finally it is very desirable that it be clear - again
like a silicon caulk. I think I would prefer it to be silicon based
and out of simplicity a 1-part type.
I tried some GE silicon II caulk after heating it up - same thick
viscosity as at room temperature and it's a bit of a 'milky' color
too. I've googled around but all I've found are surprisingly expensive
compounds marketed to large scale production operations often in
fairly large quantities. All I need is a tube or 2 of something or
other to seal up my personal project.
Appreciate any recommendations or references... - thanks
