Hello, I'm new to the forums. This is my first post.
I'm designing a cable that will allow the user to be able to transfer power between two mobile devices, regardless of whether they are an iPhone or an Android device. I have already figured out how to transfer power one way through a cable from Android to Android and Android to iPhone. It's quite simple; one end of the cable just has to have pins 4 and 5 on the micro USB plug shorted, creating an OTG cable on that side. This triggers the device attached to the OTG end to send power out of the cable, thus allowing power to be transferred from an Android device to an iPhone or an Android device to an Android device.
The problem I'm having is figuring out how to take power from an iPhone. I am 100% certain that this is possible. I know this because you can take the Apple Lightning to USB camera adapter and plug it into an iPhone or iPad, and then plug a standard Lightning or Micro-USB cable into it and be able to take power from an iPhone or iPad. I can take a video demonstrating this if necessary.
When I simply solder two lightning cables together so that there's male Lightnings on both ends, this is not the case. Nothing happens. No power is transferred anywhere. The Apple Lightning to USB camera adapter contains a PCB that somehow instructs the iPhone to transfer power OUT of its Lightning port. I essentially need to reverse engineer this PCB.
I also an 100% certain that it is possible to reverse engineer the PCB, because it looks like someone has already done it. I found online a Lightning to Lightning cable that claims to be able to transfer power from one Lightning device to another. I ordered one, and I tested it and it does what it's advertised to do. I took it apart and found a PCB inside, which presumably does something similar to the one found in the Apple Lightning to USB camera adapter. I took some detailed pictures of this PCB so anyone who's willing to help me could take a look.
I've been sorting out technical issues with my Chinese supplier for about two months now, and the only issue I have left is figuring out how this PCB is constructed, and constructing a diagram for my supplier so it can be mass produced.
Your help is greatly appreciated.
