Hi . I am newbie with basic knowledge of electronics. I need advice regarding a project.
I want to build a small narrow device which can be attached to a 16mm rod moving to and fro in horizontal direction relative to a table.The device should indicate if there is any change of more than 2 degrees in the tilt of the rod relative to the table . It would be great if the angle is adustable I.e the angle between the table and the rod. What I am looking for is that an alarm goes off when the angle changes for more than 2degrees of the set parameter. I am looking for a small sensor on the rod which can be attached to the circuitry by a 1 or 2m wire.
