I am integrating my HVAC heater controls from my car to a mini itx computer that I installed in my trunk. Mt heater controller is digital with vacuum lines. So far I connected my blower motor using switching relays via a fusion brain from mp3car.com website. So basically when I press the touchscreen monitor in my dash, the fusion brain sends signals to the relays to turn whatever relay I want on so my blower motors switches on.
For my heat and cold, it has a slide switch using resistance. I metered it's output and got these readings on various positions, I am not sure what resistors or if I have to double up on resistors to get the ohms I want. I see the beige 1/4 watt type and mohm type resistors on the controller board. Can someone let me know what type resistors to buy to get the following resistance??
The following are the ohm readings for my slide switch:
Hot: 10.01-10.08 k ohm 10.03
1: k ohm 9.72
2: k ohm 9.15
3: k ohm 8.47
4: k ohm 7.95
5: k ohm 7.35
6: k ohm 6.77
7: k ohm 6.17
8: k ohm 5.58
9: k ohm 4.97
10: k ohm 4.41
11" k ohm 3.78
12: k ohm 3.188
13: k ohm 2.604
14: k ohm 2.006
15: k ohm 1.416
16: k ohm .815
17: ohm 234.4
Cold: ohm 40.1
1: k ohm 9.72
2: k ohm 9.15
3: k ohm 8.47
4: k ohm 7.95
5: k ohm 7.35
6: k ohm 6.77
7: k ohm 6.17
8: k ohm 5.58
9: k ohm 4.97
10: k ohm 4.41
11" k ohm 3.78
12: k ohm 3.188
13: k ohm 2.604
14: k ohm 2.006
15: k ohm 1.416
16: k ohm .815
17: ohm 234.4
Cold: ohm 40.1
