need help on VGA
I have a display board for homemade computer I need help on the connection to a VGA monitor there are pin 1,2,3, which are QVSYNC, QHSYNC, XSCL would I need to connect to the VGA is there any other connection pin for the VGA to work I have a picture on the connection
Hi rambo99,
I think you would be better to work out what signals the vga monitor requires first.
And then see what signals you have.
I don't really know what you mean by a display board for home made computer.
This Wiki has the full pin out for VGA.
Martin
this board can connect to video out and LCD out I what to no can I connect to VGA as the pin have the same as VGA the maximite computer has the same connection the signal is not what I am asking it should work fine
It looks like you will need a GND connection and the BAS connection for analog video too.
But if your board has the same connector, a VGA, I can only assume that's what it is for.
