I have built several noise generators making use of zener noise but I don't know about frequencies that low(0-500Hz) because DC blocking has always been required for mine. But you should be able to set up a real quick test using a variation of the schematic found here...
noise
Replace the amplifiers shown with your favorite opamps set up as gained LPF's with the fc = 500Hz. You will also need much larger coupling caps too get closer to your DC goal.
Another note, you see from the plots on the linked page the noise levels are pretty small
(-50dBm or 10nW) after 40dB of gain. What do you plan on measuring it with(audio precision?).
Best of luck to you. And let me know how low in frequency you were able to go.
