I have a robotic cleaner that crawls along the bottom of a pool to clean it. Suddenly it stopped working.
I took it apart and I applied 24 volts (whicnbnis what it runs. on), directly to the motor. The motor began work g. This means that there is a short in the long rubber like cord that carries the voltage to the unit. So, I cut the cord, (it is really long so I have at least 5 feet to spare).
I figure I would cut it where the cord plugs into its 24 volt power supply, and keeping cutting, until I cut the shorted piece of cord out.
When I cut the cord, I expected to see two wires ( as the power unit has two prongs) and the clip that connect the power to the motor, Alsop has two prongs. However, when I cut the cord, I only found one wire (actually several wires that are bass like). see pic. How come there is not two wires and how would I deal with this?
This is the unit.
https://www.swimcsi.com/smartpool-kleen-machine.html
and manual
https://www.swimaloha.com/wp-content/uploads/2018/07/2012-PTKM100-Manual-U.S.pdf
Thank-you
This is the unit.
and manual
Thank-you
