My son has two computer power supply which he remove from the case and transfer them to a bigger case each power supply are not Join together one power supply is for one car amplifier and the other power supply for the other Ampliifer all the 12v wire are join together for amp load and GND for each power supply both power supply working OK for the two Car Amplifier the only thing he found was noise from the Amplifier output.
Is the because the power supply was remove from there case in to a bigger case
The yellow wire are not join with the two power supply
power supply number 1 yellow wire are together for 12v for one Amplifier
power supply number 2 yellow wire are together for 12v for other Amplifier
We found the problem with your help the board was not GND on the Secondary side to the case and all noise has Stop
