Platforms
Content
Hey buddy, thanks for the reply.Hi Erich, those sun roof and electric windows also have relays too.
Have you actually tested the switch with a meter?
If your sun roof opens fine but continues clicking when you close it it's most likely the relay. And vice versa opening.
As Steve said. It's a cam activated micro switch that throws the relays.
Here I took a picture from the side, it appears to be about 1cm thick, let me know if I need to take any other pics. If I can't source a replacement I will definitely try what you suggested."That picture is a generic one I found"
The switch in that picture I can find no reference to. Sorry.
It appears to be 4mm thick and off the shelf are 6mm.
Can you confirm this?
Is your switch exactly the same as in the pic?
You can try and open the swith and replace the plastic/nylon cam contact section using a dremel or similar.
Or cut a slot in the exposed worn section and glue another piece there. Shape with a dremel or similar when dry.
Possibly just a blob of melted plasted and shaped on the outside.
Failing all that, a secondhand hand car breakers and get a few.
Sorry for any confusion, to me they look identical but I'm not very educated on the topic. I've attached a pic of my switch.Firstly. Does your switch have any markings, numbers etc on it?.
It is clearly different to the ' generic ' pic you originally posted, (clarkes garage). If this is the case then a replacement may be found.
Please try to be more specific with the actual item in question rather than ' Generic ' unless they are identical of course.
Thanks for your kind comments. This is a great forum.
Martin.
Hi Hop, I tried to explain that in post 5 but clearly failed. Did you read it?Since the switch still works when you manually actuate it, I would work on adding a little extra thickness to the cam-actuated part of it
I read it (and post #6 too with the nice photo), but the OP made no response to your reasonable suggestions, so I thought I would put my two cents in, for what that is worth.Hi Hop, I tried to explain that in post 5 but clearly failed. Did you read it?
