tempus fugit
Hey all;
I've built a switching unit for guitar effects, and I'm trying to fine tune
things by getting rid of the audible pops and clicks I get when switching.
THe setup is basically this:
1/6 of a 4049 inverter input gets grounded momentarily by switch, generating
a logic hi ==============>
logic hi goes to input of 74HC373 octal latch, sending a high to the output
this hi goes to a ULN2003 relay driver ==============>
this pulls 12v through an LED and the relay coil to ground.
The relay is SPDT, and the pole selects between the input of the effect
(when it's off) and the output (when it's on).
I also have 2 channels dedicated to amp functions (channel switching and
volume boost). These require 15v from the amp to be grounded to be
activated. Initially I did this with 2 separate relays, but, in an effort to
clean up the switching pops, I decided to try to replace the relays with
transistors. This time, I routed the 5v control signal to the base of a
transistor through a 1K resistor, with a 10k resistor from base to ground.
The 15v from the amp is connected to the collector, and the emitter is tied
directly to ground. Worked OK when I breadboarded it, but now that it's in
the system, the switching pops are way worse, and there is a noticeable hum
when the 15v is grounded through the transistor. I figured that the
switching noise must have been mechanical (from the contacts making and
breaking contact), but I pulled out the footswitch unit that came with the
amp (which uses heavy duty stomp switches), and it is dead quiet. Not a pop
or click to be heard.
I'm about to start experimenting with some analog switches to see if I can
get rid of the pops when switching effects in and out, but after this
experience with the amp functions, I'm having my doubts....
So, can anyone help? Where do the clicks and pops from switching come from
in the first place? Why is the transistor clicking when there are no
mechanical parts?
Any help would be appreciated - I'm getting to my wit's end here and running
out of ideas. I realize that my description isn't too exact, but I gave you
the basic idea for brevity's sake. If more info is needed, please let me
know and I'll supply all the gory details.
mechanical parts?
