Hi
1. how should i bias:
3T GC-eDRAM (only NMOS devices)
2T GC-eDRAM (write is NMOS, read is PMOS)
in order to measure the static power consumption?
2. if i boost a signal which is connected to an NMOS' gate (in order the pass a strong value through that device), but the boosted signal is also connected to the souce/drain of another two PMOSes (their gates aren't connected to the boosted signal)- how should i bias the PMOSes' bulks? should i connect them to the "regular VDD"? should i connect them to the boosted voltage?
thanks!
thanks!
