Hi all,
New to the forum & need some guidance for a Christmas project I started not knowing it would end up getting this in-depth...
Anyway, I am making a "manly" garage wall frame type thing for my Dad. I want to have the backside of this frame back lit with LED strips. I want to run one strip of green colored LED lights on the top edge and then one strip of yellow LED lights on the bottom edge. I was looking at getting some 5050SMD lights(one of each color). They are 12v DC products.
I want to be able to run these off batteries so there are no cords to mess around with plugging into an AC outlet. The site I was looking at buying them from says a 19.5 inch length of each(30 LEDS per strip) has the following:
Green: draws 500mA(6 watts)
Yellow: draws 600mA(7.2 watts)
What would you recommend I use for a power supply? I was thinking two 9 volt batteries together(18 volts)& then using resistor(s) in a series as someone with more knowledge than I recommended. Of course I'd want a simple switch in there too. Can I run both strips on the same power source?
I really don't think this is a complicated task for most who know what they are doing & hoping to get a bit of guidance to get this completed. I am pretty good at hands on, but just want to be sure I don't fry out $35 of LEDS.
Thank you in advance!
