mike
Need help fixing thermal imager.
I have an Argus EEV P4438 Thermal Imager.
Here's the link to the pdf.
http://www.google.com/url?sa=t&rct=...mqSQBg&usg=AFQjCNF40_N9ZFJJTSQZIqiL2uYrPy4HAA
It's designed for firefighters to see bodies in dense smoke. Built in 1998
It has no absolute temperature readout. The auto-iris adjusts the gain
and I get to see relative
temperatures. That's fine.
When I turn it on, I get an image, but the contrast is low and the image
is negative.
Hot spots are supposed to be bright. On mine, hot spots are dark.
If I stand barefoot on the carpet and step off, I can barely see the
image of my footprints.
A wall-wart plugged into the wall shows up prominently, but it's black,
not bright.
So, the unit is not dead, it's just not right.
After a minute or so, a white area appears on the edge of the picture
and slowly moves
toward the center. It's like someone poured cream on the edge and it
flows toward the center.
Then the whole screen goes white. Cycling power brings it back.
There are also some artifacts in the center of the screen. Look kinda
like black lightning
flashes. It's position dependent. Point the unit down and they all but
disappear.
Point it up and they are the most prominent. They are less prominent as
it warms up.
I've done a lot of googling and reading of patents.
The thing claims to have a TGS sensor. The sensor looks like a vidicon
with a wire coming out the front
to a shielded box that I assume is the high sensitivity input. Has WAY
more circuitry than you'd expect
and dozens of variable resistors.
There's a 6V NiCd battery that measures 3V and won't accept any current
at 6V.
I assume this stores some calibration stuff. I'm afraid to replace the
battery for fear of losing
info I can't get back. Or maybe it doesn't work because the info is
already lost???
I've found mention of a "white out" phenomena that causes the screen to
go white when you look at very hot objects.
I'm looking at room temperature stuff only.
If I can fix the negative image issue, and the white out issue,
I might be well on the way to making it useful.
It's not worth spending a lot of money, but I'd like to make it work
properly if I can.
Anybody got any ideas on how to proceed?
Any chance of finding a service manual or calibration procedure?
Thanks, mike
is negative.
not bright.
and slowly moves
disappear.
it warms up.
at 6V.
already lost???
properly if I can.
Thanks, mike
