ryanm
Ok, to spare you the boring details, I keep and breed reptiles. At
present, the heat, light, and humidity for each of my numerous enclosures
are controlled manually and monitored using old-fashioned, analog gauges.
There is nothing wrong with the system I have, except that it's a lot of
work. What I would like to do is develop a set of computer controls to
automate much of this. I've have the majority of it worked out, thanks to a
small company I found that sells prefabricated, chainable circuits
(including USB interfaces) that all contain a CPU with an easy to use API
for all the major programming languages (www.makingthings.com). They take
care of the vast majority of the parts I need to build the system I want,
but there is one part that they don't make (and they want an arm-and-a-leg
to make it for me), and I need to figure out how to build it.
Basically what I need is an electronically controlled dimmer circuit to
make a proportional thermostat. It is essentially a standard light dimmer
circuit, but instead of a pot to adjust the voltage sent to the heat source,
there needs to be some circuit that returns a resistance directly
proportional to the input voltage. In case I said that wrong, let me say it
like a 4 year old: I have this other circuit with a PWM output that is
capable of sending from -5v to +5v in 1024 discrete steps, and what I want
to do is make that output control a rheostat (dimmer) that my enclosure's
heat source will be connected to.
I can follow a wiring diagram and even a schematic if it's simple. The
reason I'm using these prefabricated circuits is because I am, obviously,
not an EE and have no training in electronics. Everything I know about
electronics I learned by jacking around in the back of old guitar amps,
which contained no ICs or PCBs (I can also only work on cars that have a
carburetor). I'm a software developer by trade, so these prebuilt circuits
make it simple for me to wire a temp sensor to an input on the little module
with a CPU on it, plug the USB port into my computer, and then use the
provided API to sample it at pretty much whatever rate I want. So all that's
left is to be able to adjust the voltage going to a 110v/20a/<200w heat
source. There are a number of reasons why I don't simply put a relay on the
heat source (like the HVAC in your house), but they would require
long-winded descriptions of reptile husbandry requirements that I'm sure you
don't care about. There are also a number of good reasons why I don't simply
buy a proportional thermostat that is intended for reptile enclosures, not
the least of which is that I also want to control light and humidity, and I
want to have logging of average temps and humidity, alerts in case temps
rise or drop to dangerous levels, etc.
I would be willing to pay (a reasonable price) if someone could provide
me with a schematic and a parts list (and a wiring diagram if possible), but
a schematic I paid for I would expect to be over-engineered for fire safety,
etc (since I'm only building a few of these, I can afford to over-engineer
it to ensure that it doesn't start any fires or kill my animals). I feel
pretty confident that this is a simple circuit, since it's effectively a
modified light dimmer, and that it should be about $5 worth of parts and
less than an hour to solder together. I may be wrong about that, because
like I said, I don't know exactly what's involved, but I'm sure there's an
IC that can replace the pot in a standard light dimmer circuit so that I can
adjust the resistance by varying the input voltage, I just don't have any
idea how to find out what, if any, IC would do the job.
Any help, pointers to urls, or sanity checks are appreciated. Let me
know if you need more detail or if I left out anything major. Oh, and the
standard disclaimer for these groups: I'm not a student trying to get you to
do my homework, I'm not trying to get someone else to do my job, this is a
hobby project and I have hit the limits of my experience. I myself hang out
in programming groups and email lists and play the geek with all the answers
for the newbs, so I figured there must be someone similar in here who can
either point me in the right direction or who would be willing to do it for
a reasonable price. Thanks.
ryanm
ryanmAThorsefishDOTnet (do the obvious to email me)
ryanm
