Pico fuses..I had thought that they were sealed....If you look at the inside of a RJ11 telephone connection box like the ones that mount on your baseboard,(or some tele-communications equip)... you will probably find two very small green colored components inside..they are used to help protect the equipment from spikes on the phone line.... the rating is printed on the body...These are pico fuses......if you can remove the outside covering, then I don't think they are pico style...the fuse that you had I have found inside power supplies inside some orion laser lights....they just have a black covering over them which looks like heat shrink tubing.........
