Doug Kent
I have been doing some research on connecting my laptop to the combus of a
DSC Alarm panel to create a virtual keypad and to better understand what is
happening there. After searching the newsgroups I came across some threads
from people who have tried but it did not appear they had any luck with
their attempts. About 2 years ago I built a circuit connected to a keypad
and wrote a VB program that would read and write to the parallel port
connected to the push buttons to create a virtual keypad. It worked but was
a very poor design. I believe connecting directly to the combus would be a
far better way to communicate. Being able to control the combus would allow
me to interface the alarm system with home automation programs. From my
research and testing it appears the combus on the alarm panel is made up of
Ground, 12 volt B+ line, Data and Clock. I have been able to lock onto the
data stream with my scope using the clock pulse for sync but have not had
any luck finding a converter that will convert the 0 to 12 volt data
stream and clock pulse into RS232 for my computer. I was wondering if
anyone can help me out with a circuit to connect the TTL combus to a RS232
serial port on the computer. After I have connected the computer to the
combus next question is cracking what type of structure.
Any help you can give would be appreciated.
Doug
[email protected]
Doug
[email protected]
