Need help about CMOS domino logic
Here is the Logic, I forgot to add Z(output) out of the NOT Gate.
Anyway, I understood that Dynamic Logic is controlled by MOSFET's internal capacitance,
I thought MOSFET A-E's internal capacitance will charged, but I knew that this is not correct
(I didn't know that PZ has parralel capacitor.)
if this right, I thought that when Φ is 1, Capacitor PZ discharges to left N-FET, Z(output) is on, even Φ is 1 cause Z's capacitor(like PZ Cap).
And another question.
if A,B is closed and left P-fet off,N-fet on -> Can PZ cap discharge? Cap will have GND to any side.
I may not fully understand the phrase. But: consider the logic gate pe se (i.e. without the buffer-inverter). The logic function is PZ=(A*B)+(C*(D+E)) where *=AND and +=OR.
When Φ = 1, this logic function is evaluated, PZ takes on the respective logic state and the buffered output of the gate is NOT(PZ).
When Φ = 0, the lower left NMOS is off, the upper left PMOS is on. PZ is pre-charged to logic 1, leafing the output NOT(PZ)=0.
In the gate(s) attached to the output of this gate this will turn off all NMOS input transistors. Only when Φ goes high again will the output of this gate change state according to the logic function and the inputs of the following gates will follow suit.
Yes.
By the way: this smells like homework. If so, I can move it to the correponding forum section and I kindly ask you to post in the right section next time.
I understood it.
Z(Output) also has virture CAP, so it charges output and discharge while PZ is over right P-FET's threshold V.
So the answer is A.B + C.(D+E)
thank you for your advice.
and I'll find correct forum section next time
