Need a Signal from a Diesel Injector
Hello all, I need to get a signal from a diesel injector. My understanding is diesel injectors work on voltages around 70vdc and around 1 amp. I was thinking of using an opto-isolator but I also was thinking a 12v zener would work and would make for a simpler circuit. Does anyone know if a zener adds resistance? I don't want to change the resistance of the injector.
The injector signal from the vehicles ECM is a square wave. Whats the best way to convert it into a triangle or sawtooth? I was thinking send the signal into a 555 ic
My first thought would be to use an opto isolator whose output is configured as a common collector this will provide a good deal of isolation to the rest of the circuit. How pure dose the triangle/sawtooth waveform have to be?
Adam
Adam thanks for jumping in and helping out.
Doesn't need to be very pure. Im basically looking to use the injector signal for timing but I was going to feed the signal into a compairitor so I could control duty cycle so the square wave generated by the ECM for the injector won't work.
Ok so it could be as simple as a passive integrator then. The problem comes if the frequency of the injector timing changes, will this happen? Do you know the frequency of the injector square wave?
Adam
