Need a SD (memory card) controller chip.
Boki
Hi All,
I need a SD memory card controller chip, I also need to porting some
MCU code, and need UART interface, low speed as 9.6K is enough.
Best regards,
Boki.
Boki
Boki ¼g¹D¡G
Hi All,
Best regards,
Boki.
Dear All,
Due to the cost, I hope it only support SD ( no need to suppor others,
ex: CF, MMC,...).
Best reagrds,
Boki.
Nevo
SD cards must support the SPI interface. So any microcontroller with a built
in SPI interface can control an SD card.
You can download the MMC card spec from SanDisk to get the details.
PeteS
The MMC spec is not the same as the SD spec, unfortunately. One can get
a copy of the minimal SD spec for free but not the whole spec without
joining the club. The entire spec is necessary to fully implement SD.
I am using a device from Winbond that supports SD and SDIO, but I had
to sign NDAs to get the source. I have no doubt you will run into the
same issue.
Cheers
PeteS
Adrian Jansen
Boki said:
Hi All,
Best regards,
Boki.
Have a look at
http://members.aon.at/voegel
and related:
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewforum&f=9
Regards,
Adrian Jansen adrianjansen at internode dot on dot net
Design Engineer J & K Micro Systems
Microcomputer solutions for industrial control
Note reply address is invalid, convert address above to machine form.
K
Kryten
same issue.
I heard that:
1. SD is a superset of MMC, thus MMC code can use SD cards
2. The 4-bit SD interface isn't a big deal
3. Only the 'secure' aspects are closely guarded
4. The security has been cracked, so it isn't secure
5. Almost nobody uses the security features
So I presume one can get code to use SD cards without the complete
specification.
Boki
PeteS ¼g¹D¡G
same issue.
Cheers
PeteS
Thanks a lot, I think NDA is not an issue. :)
Best regards,
Boki.
W
werty
I dont think he will run into the same issues , nor will i .
The market will be free , or it will die , take your pick ....
Patents hold society hostage by those who only copyied
others , but got to patent office first !
Can You say Bill Gates !
Joe Birch
Did you find an SD Card Host controller?
I am looking for one and could use some help.
The dosonchip looks interesting but i think would be too slow.
I need a concurrent write of 1Mbytes/s and a read of 2Mbytes/s.
A USB to SD card bridge would be OK. or a SD Card Host controller with
a A/D bus.
I need to keep the cost <$10
Joe
