steamer said:
--Yeah that's the kicker; it seems like any scheme I can dream up
will require something like a car battery to keep things going, then I'll
have to charge the battery periodically. What I'm hoping for is something
that can work with a smaller battery that isn't awful to hump around; maybe
a lantern battery?
"Steamboat Ed" Haas : Whatever happened
Hacking the Trailing Edge! : to Porgy Tirebiter?
www.nmpproducts.com
---Decks a-wash in a sea of words---
Hi, Ed. You know, I'd think the thing you're looking for would be
commonly available for a relatively low cost, particularly with
automotive and camera applications.
I was looking around a little bit, and saw a relatively inexpensive
setup made by RFSolutions, a British outfit. They've got the whole
kit, with keyfob transmitter and receiver that operates on a 12V
supply. It's not high power -- two 6V lantern batteries in series
should work for a long time. Looking at the receiver datasheet, you
might want to go with the momentary relay outputs (switch selectable),
and use them to drive a dual coil magnetically latching relay for
minimum power consumption if that's an issue.
Their products are available through Maplin, a UK hobbyist distributor
kind of like Jameco here in the States. I know we can order from them
with a credit card online or by phone in the States, and you can also
get help online or through email.
The webpages don't show very clearly what you're ordering -- you might
want to email or call them for assistance.
http://www.maplin.co.uk/module.aspx?ModuleNo=35626&doy=28m5
http://www.maplin.co.uk/Media/PDFs/RN51_RN52_N79BN_N80BN.pdf
I haven't used these myself, but your question made me curious. I'd
like to know if these are what you're looking for. I was kind of
hoping someone else had a solution.
Cheers
Chris
