I traced the Drain connections to the corresponding output pins on the board connector, Pins 10,11,12 are the 5VDC output connections. Pins 2,3,4 are the 12VDC output connections. The filter capacitor correct voltage ratings confirm these outputs.
So CRS101 (NF818) is for the 5V supply, and CRS102 is for the 12V supply. They are a TO-220 package. They are insulated from the heat sink.
The board legend says it is 5VDC@5A and 12VDC@4A. Given the polarities I am assuming these are N-channel MOSFETS.
Vishay Siltronix makes a IFR840, SiHF840 (TO-220), and a SIR818DP (but in a SO-8 package which won't work), Maybe this is a bad cross.
I have little experience with MOSFET's.
Anyway, this is all I have. Could you help me find suitable replacements.
Thank you so much!
Eddie
