Beachcomber
I have a PBX phone system that uses the somewhat odd voltage of 28 VDC
at 1 amp. The current supply is a giant wall wart AC-DC convertor,
but this has no standby capacity if the AC fails, even for a second.
It doesn't fail often, but when it does, I spend about an hour
reprogramming the thing from scratch.
I was planning on buying a regular 120 VAC in 120 VAC out UPS and
plugging in the wall wart to the UPS, but then I thought it might be
possible to simplify the circuit if I had some sort of UPS that puts
out 28VDC at 1 amp directly and has some sort of standby/rechargeable
capacity.
The problem is this seems to be an odd voltage and after numerous
searches on the Internet, I don't seem to be able to come up with
anything that closely meets these specs. Budget is a consideration.
I can afford about $100 or so. I've never seen a 28 V battery
though. Two 12 Volts in series would give 24 volts, almost, but not
quite enough.
Does anyone have any suggestions on the best way to (cheaply) deliver
28VDC at 1 AM with a UPS backup function? Thanks in advance...
Beachcomber
capacity.
quite enough.
Beachcomber
