NEC Power Transistors - need info -
Z
Zeljko
Hello,
I'm trying to find the equivalent of two NEC power transistors, it's a
NEC 2SD188A and a NEC 2SB545A.
I need some technical info of those transistors or datasheet? I have
Sasnui receiver and one channel doesn't work. Thanks in advance! Best
Regards!
Zeljko
F
François Yves Le Gal
2SD188(A)
Si bipolar NPN TO-3
Vceo = 80 V
Ic = 7 A
Pmax = 60 W
Hfe min./max. = 30 / 120
2SB545(A)
Si bipolar PNP TO-3
Vceo = 70V
Ic = 5,0A
Pc = 60W
Trevor Wilson
Zeljko said:
Hello,
Regards!
Zeljko
**VCBO - 100
VCEO - 100
Ic - 5A
Pc - 50W
hFE - 50 (@4A)
fT - 10MHz
Z
Zeljko
Dana Sun, 24 Jul 2005 23:14:08 +0200 na news grupi
sci.electronics.repair
osoba pod imenom François Yves Le Gal je napisala...
2SD188(A)
Si bipolar NPN TO-3
Vceo = 80 V
Ic = 7 A
Pmax = 60 W
2SB545(A)
Si bipolar PNP TO-3
Vceo = 70V
Ic = 5,0A
Pc = 60W
Thank you guys!! Thank you very much!
Best regards from Croatia!
Zeljko
