I recently installed a Napco LCD bi-directional keyfob. All keyfob
functions seem to work well except for the sense mode options. The
remote will arm and disarm the alarm and open and close the garage
door; however, the remote doesn't accurately display the status of the
system when triggered from either contact 5 or 6. The remote status
constantly displays that the alarm is armed (a closed lock icon
displays on the remote). I have manually forced 12v + to both contact 5
and 6 and switched jumpers A and B on and off to no avail. The keyfob
transmitter is connected to an Elk M1G so it is confirued for universal
mode not bus mode. As a result an ID can not be programmed into the
remote as in bus mode. It doesn't seem to be a remote hardware problem,
becuase, both of my remotes respond with the same locked status icons.
Does anyone have any ideas?
Thank you for your assistance if you have any suggestion.
