Name them Parts
Hi folks:
A friend of mine gave me some electronical components that he isn't using. He does not know what they are, and neither do i. I have taken a pic of them and numbered them. if anyone knows what they are and their function, please let me know. Don't trouble yourself though. I can resarch these, but if you happen to know, all the better.
Thank-you
1. Hearing aid
2. Cheese grater
3. Night vision goggles
4. Small brick
5. Miniature hockey puck
6. Pin comb
1. Dual axis joystick module
2. LED matrix
3. Ultrasonic sensor
4. ? Relay?
5. Piezo buzzer
6. Triple access accelerometer and maybe a gyro too.
I think your friend aquired them from somebody who plays with Arduino or other types of microcontroller.
Martin
bertus
Hello,
Item 1 is a thumb joystick:
https://makerfabs.com/index.php?route=product/product&product_id=76
Item 2 is a 8 X 8 led matrix display, see attached datasheet.
Item 3 is an ultra sonic distance sensor, see attached datasheet.
Item 4 is likely a relay, as I can not read the data on top, I can not give any details.
Item 5 could be a buzzer of some kind.
Item 6 is an 3-axis motion sensor:
https://www.elecrow.com/triple-axis-accelerometer-gyro-breakout-mpu6050-p-322.html
https://www.elecrow.com/wiki/index.php?title=MPU-6050
http://www.elecrow.com/download/PS-MPU-6000A.pdf
Bertus
  • HCSR04.pdf
  • matrix display 788.pdf
#1 looks like an encoder or joystick of some sort.
#4 is probably a relay. How many pins are on the bottom and how are they spaced? Are you able to get a better pic of the numbers printed on it?
#5 is either a piezo transducer (mini speaker) or a buzzer.
Google the numbers usually brings up details, however ........
DPST relay similar to this .....only yours is 5v dc coil......3A 2250vac switching
Just a word of warning here...some of these relays will be polarised on the coil, meaning they already have a freewheeling diode installed inside the relay.
Get the connections A-About and it'll be a dead short on your supply line.
hevans1944
Hop - AC8NS
Wow! From stomp box to really high-tech electronics toys... you're hooked! Yer life will neva be the same. Mua ha ha ha ha! Ummm... we can help with that.
