Nakamichi TA-2 Receiver in a funk
j
I'm trying to troubleshoot a 1980'2 era Nak receiver that has pushbutton input switching via a microprocessor (can also be remote controlled). The button lights don't work, and I get no input connections at all. Strange, but the micro works, controlling the volume up and down. Also, the amp worksvia the pre-out and power-in jumpers. Apparently, some aspect of the switching (done via an analog switch IC) is screwed up. Anyone have ideas on how to troubleshoot this?
chuck
I'm trying to troubleshoot a 1980'2 era Nak receiver that has pushbutton input switching via a microprocessor (can also be remote controlled). The button lights don't work, and I get no input connections at all. Strange, but the micro works, controlling the volume up and down. Also, the amp works via the pre-out and power-in jumpers. Apparently, some aspect of the switching (done via an analog switch IC) is screwed up. Anyone have ideas on how to troubleshoot this?
I would first check the electrolytic caps in the power supply. Noise
on the B+ lines will cause all matter of digital problems with this
model. Chuck
N_Cook
What ident is the big an. sw. ?
j <[email protected]> wrote in message news:[email protected]... I'm trying to troubleshoot a 1980'2 era Nak receiver that has pushbutton input switching via a microprocessor (can alsobe remote controlled). The button lights don't work, and I get no input connections at all. Strange, but the micro works, controlling the volume up and down. Also, the amp works via the pre-out and power-in jumpers. Apparently, some aspect of the switching (done via an analog switch IC) is screwed up. Anyone have ideas on how to troubleshoot this? What ident is the big an.. sw. ?
There should be a switching IC (LCxx22 or TC9163) located on the board. Inmany cases this is the problem. You will see the signal entering the IC, but no output. I believe that the light and the audio are controlled by the same line. The few of these I have seen in the past were quick fixes by replacing the switching IC. (IIRC)
Dan
Mark Zenier
Did Nakamichi do the thing with the button lights that they did on some
other units? (The lights were used as the pullup resistors in the matrix
scanned keyboard or something strange like that).
Mark Zenier [email protected]
Googleproofaddress(account:mzenier provider:eskimo domain:com)
Mark Zacharias
model. Chuck
I was able to download a service manual from Elektrotanya.
The site is difficult to access if you don't speak Hungarian but I can email
you the manual.
email me at:
[email protected]
and reverse "labolgcbs" to read "sbcglobal".
Mark Z.
