L
larrykeegan
I have to admit I posted this info
elsewhere, but here it is
because of my background in programming and electronics
I am determined to send a line of random data to
program memory and then to READ it back confirming
that the prgrmng was successful
I am utilizing 160 pgs of elect specs & 20 or more pgs
programming spec's found on the internet.
I've noted some problems people have had with
more sophisticated programming software
so far I've changed my hardware (homebrew)
twice
when I program my one line of random data into
pgm mem, I then try to read it back, mainly with an LED
option to look at data appearing at the DATA pin
when it is in output mode
so far no signs of life with my PIC
I have brought my mclr & pgm volt up to
5v (rather than just logic hi - say 3.5)
I am proceeding on the basis that there are no MAX
time constraints on the clock and data signals
when I raise mclr & pgm I am assuming
PC says zero as the loc for loading my data
in my read pgm when I raise mclr & pgm
I also assume I am at loc zero
I am also assuming that config says 1
for low volt pgming
are any of these assumptions faulty?
Larry Keegan in Stoneham, MA, USA
twice
for low volt pgming
