Sir Nokianas . . . . . .
With the forthgoing supplemental text of our Right Honorable and Esteemed colleage, Technomniac's info, you should have this situation all nailed down.
I initially declined reply, until a further in depth circuit design analysis confimed that your volume control was not feeding a variable DC voltage into a variable electronic gain block.
This provided schematic / wiring diagrams " relevant snippet " now confirms that not being the case, its just using an " old school " conventional variable voltage divider attenuator . . . . . ergo . . . no " fly by wire " techno design aspects are being incorporated.
THE UNITS AUDIO SIGNAL FLOW PATH . . . .
Hold on tight and lets go thru an audio circuit run.
AM or FM audio comes in at the top right corners
RED arrows and flows across and down to the Radio input of section 2 of Switch 601 and out its rotor and then down *** to the A terminal of the volume control and its rotor / wiper portion passes the signal on to coupling capacitor C712 and on thru it to the base of the Q702 transistor which amplifies the signal and then passes it on to the audio power amp section that finally feeds the units frontal speaker.
(*** Coincidentally, that same audio signal also feeds across to the Radio terminal of S601 section 4 to connect into the series audio tone control circuitry composed of C721 and RV702 tone ontrol.. )
Now refer to the right sides
YELLOW inserts of three volume control setting variants.
Max Vol has very little series resistance between A and B and thefore gets max signal thru and there is a high resistance path between the B wiper and C terminals ground
Mid Vol has moderate series resistance between A and B and thefore gets further reduced signal thru and there is a now lower resistance path between the B wiper and C terminals ground, thereby weakening the signal even further.
Min Vol now has considerable series resistance between A and B and thefore gets greatly reduced signal thru and there is a now a very low resistance path between the B wiper and C terminals ground, thereby weakening the signal even further.
You now have told us that at max volume that the unit is outstandingly / excessively loud, and at mid volume is still way too loud, and even at lowest volume, that it is still being too loud.
Now with you being able to differentiate and establish different volume shifts within that total range, that the volume pots A-B resistance changes are being good,
BUT subtle, it just seems to have a problem in the B-C loop that grounds out a portion of the audiio.
The grounding of RV701 C terminal . . . . or . . . .Where do I go ?
Well ? . . . . . . in consulting the map and with GPS back-up you can go down to the first BLACK dots junction and can go to the left to
find that the S601 section 1 is having no termination on its Radio position.
So, now lets go back to the right and then find that path will run into terminal 3 of RV702 tone control.
HEY ! . . .you know whuts . .it looks like the tone control is needing to
SHARE the same path to ground as the volume control uses.
Perchance, did you check to see if the tone control had any effect on your audio ?
Tone control works thusly . . . .
You have my earlier referenced alternate audio path into S601 section 4 at the Radio terminal and then out the wiper into C721 0.066 ufd coupling capacitor and then down into terminal 2 of RV702 tone control, thru the resistance path to terminal 3 and it finally grounds.
With the tone being at max resistance of 1-2 position and the resultant series audio path thru C721, will have the least tonal coloration effect upon the audio. Then, as you start rotationg terminal 2 towards terminal 3, there are more of the highest audio frequencies being filtered off to ground. Now you . . .ole fewl that you are . . .think that you are a gittin' mo' BASS . . . . . while you are being fooled by the decrease of the treble frequencies presence .
Lets now follow that last possibility left and go straight down with
C terminal and initially encounter
P terminal of S701 section 1#.
Thats
P as in
Playback and not its alternative
Record option.
Now I / we know that in order to preclude accidental / unwanted record-over, that this electrical switch is mechanically interlocked such that
BOTH hands, two thumbs , three fingers and two vile curse words are equired to successfully get it latched into its actual record mode.
Now since I also know that you are merely wanting to be listening to the radio, I am seeing that they have the
BLACK switch contact bridging the switch into its record mode. I am now correcting and inserting the actual
RED dotted in switch contact position, in place of the
BLACK position used when recording. . . .and that reverts it to normal
Playback mode.
BEHOLD . . . now use the
GREEN arrow grounding path to travel down into the Play terminal, thru the
RED slide contact, and up and out the center switch contact and finally into the large wide
BLACK ground buss.
Now . . . . . HOWDOYOUDOITTOIT ?
This will be back and forth between the two reference types, initially using the RV701 pot photo to see that terminal B has the worst looking solder blob surround . . . .
BUT . . . . A and B seem to minimally change the volume.
YOU . . .yes, you, can see the green resist covered foil at the C terminal and also see which directions it branches out to and eventually connects to.
I tend to think that the 4 ORANGE pot support brackets might be grounded, and valid grounds but only you can see the foil paths to confirm.
I can see that my
VIOLET rectangle marked up C711 BLACK electrolytic is NOT showing a silver ground band on its viewable side so I can correctly assign that wire terminals solder blob a
RED circle positive polaity marking.
SO . . . . that makes its next inwardly located wire and its solder blob . . .
BLACK X marked . . . . terminal as being
NEGATIVE polarity, and it is definitely a ground connection on the schematic as its now marked in
BLACK X.
Now you use that same jumper wire used before and place one end on this now confirmed ground and the other wire end at the
C terminals hole. With the volume control B wiper rotated near C terminal end the volume should drop upon the jumpering action.
If it does, it is then just a further tracking down of the few other points on the
GREEN arrow path to ground.
If no volume drop, we need to look into the left pages side of the inset of the
YELLOW outlined contact portion of C of the pot.
Thaaaaaaaaaaassit . . . . . .
I now await for the findings of your situation(s) . . . . .
VISUAL REFERENCING DATA . . . w / its marked up . . . . connotations
73's de Edd . . . . . .
