I am experimenting with a relaxation oscillator circuit consisting of
a NE-2 bulb wired parallel to a capacitor and this pair is wired in
series with a resistor and connected across a 150 V DC power source (a
bunch of DC wallwarts connected in series). The resistor is variable
0-1 Meg Ohm, the capacitor is a 1uF electrolytic rated at 160V. I
don't have any capacitors on hand with a higher working voltage.
The circuit seems to work. I can get the bulb to blink around 3 times
a second but I am wanting a higher flash rate and I am not getting
it. Lowering the resistance makes the bulb turn on continuously. I
don't think that the bulb is flashing faster than the eye can
distinguish. I conneded the circuit to an oscilliscope and when the
bulfb is visually flashing I see the RC discharge curve but lowering R
until the bulf truns on continuously pretty much produces a flat line
on the scope.
I was expecting to maybe be able to get around 2-100 hz with a NE-2
relaxation oscillator. Is this possible or am I expecting too much
from this type of circuit? And if so, why?
Any help would be greatly appreciated. Thanks
on the scope.
