Radium
Hi:
I wonder if a diaphragm-less loudspeaker could use a mechanism similar
to a stun gun. The spark from a stun gun does not produce any
perceptible heat in close proximity because -- despite being a 100,000
volts -- the power is not enough to raise temperature sufficiently to
burn the skin.
That being said, the stun gun does make sound when it sparks. I assume
that an equipment similar to the stun gun could be engineered so that
it could produce sparks that would cause the intended sound [e.g.
speech or music]. The sparks can be modulated by the audio signal,
thereby reproducing the sound.
If an high-voltage, low-amperage electric current of 1,000 Hz frequency
is passed through air, a 1,000 Hz tone will result.
In my previous post, I was erroneously reffering to this type of
speaker as "plasma". I am now aware that the speaker I am describing is
not "plasma" because it does not use the high-power required to produce
plasma. Rather it uses high-voltage, low amperage "lightning" to
reproduce sound within the air itself. The frequency and wattage of the
electric current passing through the air is determined by the frequency
and ampitude of the audio signal.
Potential advantages, I can see, are higher-frequency response and
greater tolerance for loud volumes and clipping that would rupture or
burn speakers with diaphargms. This loudspeaker I am describing also
has advantages over actual plasma speakers [e.g. ionophone].
For example, this loudspeaker:
1. Does not produce ozone
2. Does not require ionizations of gases
3. Does not require a supply of its own gas [e.g. helium required by
plasma speaker]
4. Does not require drastic changes in temperature to produce sound
5. Does not consume large amount of power like plasma speakers do
Thanks,
Radium
burn the skin.
plasma speaker]
Thanks,
Radium
