Hey Guys,
I have a quick question about a power supply hookup I am currently doing. Basically I have a 24VDC to 5VDC converter which has two 24VDC sources connecting to 1 input. The converter charges a battery and is located on a vehicle that docks every 2 minutes. The charging sources will never be running at the same time. Source 1 is a plug that is plugged in for over night charging and Source 2 has open contacts so that every time the car is docked, the battery charges. The problem I face is that if source1 is plugged in, the pins from the second source become charged. It may be possible for someone working on the car at night to accidentally short the contacts on Source 2. I need a way to keep the voltage to only the source that is currently being used for charging.
I know I can put a diode on the incoming power wire, but I am not sure if this will give me a complete open circuit for source 2 or if i will still get some voltage back across the diode. I have contemplated building a simple switching circuit which opens the contacts on the opposite source when one source is plugged in but I'm in a time crunch and limited on space in the box which the converter is located.
Here is a very crude drawing of the setup:
If I can get away with just putting diodes then that's the route i'm going to take. Just need a second opinion.
Any help is greatly appreciated!
